Any F-21 Headliner removal tricks
  • Any F-21 Headliner removal tricks
    I would like to change my GPS antenna mounted on the wing top over the cockpit. It appears the headliner needs to be removed to access the antenna. Are there any tricks to removing the headliner. My concern is not to damage it in the process.
    Pictures would help...
      When you put it back in use more hooks and Velcro. You are going to need to pull it down again in the future.
