Has anyone heard of using par-alketone to wipe control cables for corrosion protection? Does it attract grime and dirt? Experimental planes only?
Par-alketone
Re: Par-alketone
Long ago while maintaining fire fighting planes for Rosenbaulm Aviation in Medford, OR, that was one of the winter jobs was wiping that stuff on the cables in the back of the aircraft, it dried, was flexible, but not sticky, garyOriginally posted by SpecialT View PostHas anyone heard of using par-alketone to wipe control cables for corrosion protection? Does it attract grime and dirt? Experimental planes only?
http://www.aircraftspruce.com/catalo...aralketone.php
Re: Par-alketone
I understand it to be standard practice.Originally posted by SpecialT View PostHas anyone heard of using par-alketone to wipe control cables for corrosion protection? Does it attract grime and dirt? Experimental planes only?
I was surprised to see it is not listed in AC43.13-1b. May be in the AMT manual for airframes or general.
My first encounter with it was in the '60s. Have some in my shop now. Good for cables.
Have seen it used to coat inside of tubing also but I think that is a bad idea.
Dave R
Re: Par-alketone
http://content.aviation-safety-burea...otection13.php Dick
Note: I think this link is to the basic document AC 43-13-1B...BEFORE a couple of updated versions that are more current. Anyhow, this was apparently accepted practice back in the day.Last edited by Dick Smith; 12-16-2017, 23:24.Dick Smith N5207M TF#159
Re: Par-alketone
I wonder why that looks odd, the AC 43.13-1B CHG 1 i have shows control cables in 6-75 and (b) just says to use a preservative after removal of external corrosion, that last statement also seems strange, if a cable has external corrosion, it probably has internal corrosion, maybe its just me after a long day of magneto work, gary
Re: Par-alketone
Thank you Dick,Originally posted by Dick Smith View Posthttp://content.aviation-safety-burea...otection13.php Dick
Note: I think this link is to the basic document AC 43-13-1B...BEFORE a couple of updated versions that are more current. Anyhow, this was apparentlyy accepted practice back in the day.
I thought I was loosing my memory! :-)
I should have looked at a older paper copy of AC43.13-1A.
Re: Par-alketone
Par-al-Ketone is basically a form of Cosmoline, you can use it on any steel surface where corrosion is potential. I acts like a grease until the solvents evaporate out then its like a sticky wax from my experience. TimN29787
Re: Par-alketone
I was thinking it was a wax/paraffin type of product.Originally posted by astjp2 View PostPar-al-Ketone is basically a form of Cosmoline, you can use it on any steel surface where corrosion is potential. I acts like a grease until the solvents evaporate out then its like a sticky wax from my experience. Tim
