I suspect that most of the fleet has been retrofitted with lifetime sealed struts by now, but since I'm "in the market" I was hoping to draw on the collective wisdom found here. Are there any lessons learned concerning the replacement options that point to a "best" solution?
If going with brand new, is there a real standout among the various suppliers or is price really the discriminator?
Considering these are going on a BL-65, every ounce counts. Is there a difference in weight among the variety of new struts?
"Remanufactured" struts are available at significantly lower cost than new- any issues with these?
In short, if you had to do it all over again, would you stick with your choice or take another approach?
Many thanks
Many thanks
