Trim Adjustment Screw - B12-406
    Re: Trim Adjustment Screw - B12-406
    Spare parts:
    Tim Hicks
    N96872
      I could use one or two of those to build patterns from!
        I would be nice if the thread profile turns out to be one of the unified thread standards but that is not typical for leadscrew applications...
        @TimHicks - are all those "spare parts" your spare parts? When someone earlier suggest I just by an elevator is that because someone has one available to sell? My t-cart has generally been so reliable I haven't had to look for many parts (been flying it since 1986...).
        Steve Stearns
        BC12D N43732
        Boulder CO
          Well, best I can tell the thread profile IS standard. My example part measures as 0.5-13 (UNC). If there is a place to post a .pdf here, I'll post my first draft part drawing. I've attached it here as well. This is an untested draft...
          Steve Stearns
          BC12D N43732
          Boulder CO
            I was thinking that the threads were pretty common, not much was very special in 1941 when it was designed. Tim
              Sorry for the confusion. Those "spare parts" are not mine. They belong to Bob Wagstaff in Laporte Texas. If you search this Forum, you'll find contact info for Bob. He's got a lot of TCraft parts.
              Tim Hicks
              N96872
                Rob referred to brass, DJ referred to bronze, Tim ask which one. I have not seen it answered, so I'll ask again:
                What material is the male part? Brass? Bronze? What alloy?
                Anyone wish to voice an idea?
                Mike Wood
                Montgomery, TX
                '46 BC12D
                N44085 #9885
                  I'm not a TCraft expert, nor a metallurgist, nor a machinist. But I've made plenty parts on mills and lathes (manual and CNC). And I've had a lot of stuff made in machine shops by much better machinists. And some of that stuff has been in brass.
                  I don't really know the difference between brass and bronze. But I don't think I've ever hear the word "bronze" uttered in a machine shop (maybe "bronze bushing'). And they always have some pieces of brass available for machining.
                  Maybe the shop's material is bronze and they just call it brass. I don't know.
                  If I had to hazard a guess, I'd guess that it's brass.
                  Tim Hicks
                  N96872
                    The word "Bronze" is derived from the Italian "Bronzo" which means "bell metal brass". Brass is a specific kind of Copper alloy made with Copper and Zinc in different percentages. Bronze is a broader term for Copper alloys that are mostly Copper, usually with about 12% Tin and may have Aluminum, Manganese, Nickel or Zinc as metallic additives and may even have non-metals like Arsenic, Phosphorus and Silicon. When Copper alloys were the best and strongest metal available, adding these alloying agents to Copper was the best we had for getting Copper harder, stiffer, more flexible or easier to shape. Not much reason for using them with all the modern alloys available. Where Bronze seems to still be the material of choice is for bushings because of it's anti seizing properties.
                      A lot of bronze is oil impregnated, many are also sintered, pressed together from small filings under tons of force...tim
                        This task isn't done yet... I'm currently doing investigations to identify the particular alloy of brass that was used. This sure would be easier if we had access to the original fab drawing...
                        Steve.
                          Can anyone provide me a non-serviceable trim adjustment screw for destructive testing to determine the specific brass alloy?
                          Turns out the testing organization needs more material than I hoped so I can't use the trim screw I borrowed to make the measurements. And my other one, of course, is still installed in a flying aircraft.
                          Please let me know if you can. I will post, as I did my drawing, the results so that we may all benefit.
                          Steve Stearns
                          Taylorcraft BC12D N43732
                          Boulder/Longmont CO
                          • #28
                            Steve,
                            Perhaps you could make one from stainless steel instead.
                            Certainly as strong. machineability might be an issue.
                            • #29
                              Another thought, have you looked in MIL Handbook 5 to see what alloys are recommended for aircraft structures?
                              That may whittle down the options.
                              ahh... only Copper beryllium and manganese bronzes are included in MIL-HDBK-5. Alloy C17200, that may be your answer. It is the same as AMS 4650 and AMS 4533
                              Dave.
                              • #30
                                I would look in the machinist handbook first, the tool engineers handbook second. It is probably just standard brass that they make gears from. You could also check for brass bar stock at McMaster. Tim
                                Here is one example of what is available
                                McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
                                and a second
                                the second would probably be the best.
