Quick backstory.. Grandpa has owned this Tcraft since '77, I've been sole mx on her since 2012. Before that is was all grandpa and his IA.
Couple months ago when it started getting cold I had a but of a stutter at 1300-1400 rpm, above or below that it ran great. So I backed the idle mixture screw out 1/2 turn. Ran fine, even did my commercial checkride in the Tcraft. Showed back up this weekend. Gave it another 1/2 turn back to see if that would help, it didn't. So I'm suspecting a blocked bleed port in the carb. I pull it, split it and find this.... I pull the bottom drain every annual and let fuel flow for a few seconds to clear it out. Apparently that isn't enough. What is the tribe doing for this on their strombergs?
