I would like to put the controls mounted on the small sub-panel below the main instrument panel in my 1946 BC 12D in the correct position as they left the factory. The only one I can definitely locate is the throttle in the center. Where do the others go exactly?(carb heat, fuel tank shutoff, cabin heat primer). Does anyone have an original flight manual/P.O.H.? I would pay costs for a copy.
Brian Neri
Brian Neri
