f-19 exhaust
    Re: f-19 exhaust
    I tipped the cessna exhaust in on one airplane, it wound up causing a few issues to clear everything...also install the supports from the bottom of the engine/spider area to the clamps for the outlet pipe, it keeps things from cracking. Tim
      Re: f-19 exhaust
      Thanks Tim for the advice. Not sure what bracing to the outlet stacks is there now but will recheck and monitor. The header pipe for #2 - left rear is a tight fit and requires some adjustment in shape and width.
