Bonjour
Re: Bonjour
Hello Jacques,
Bienvenue!
You will find help here (soon, I hope), but the Swick Taylorcraft is not as common as the factory-built one of course, but there are several members here who own clip-wings, so any help will be forthcoming.
Have you seen a factory Taylorcraft? (I may be flying mine to your area this summer).
p.s. Votre anglais écrit est très bon! Il n'est pas surprenant que vous êtes un pilote professionnel!
Re: Bonjour
Jacques,
Also consider the Cole clipped-wing . I think plans are available.
The Irish Taylorcraft is probably airworthy as it is, on a UK LAA Permit to Fly (similar to the Canadian "Owner-maintenance" system). So as a start for a Clip-wing conversion, it may be expensive.
I know that the French DGAC have problems with factory-built aircraft on a Permit / Experimental system.
But there are so many modifications that I would suggest you purchase a fuselage from the USA, and go from there.
There is also a Howard T-Minus in the UK http://www.taylorcraft.org.uk/BRXS.htm. This used to be aerobatic in the USA, but not in the UK. It is built like ... comme on dit en Francais... un commode des briques
All the best,
I think the closest I have been to your home airfield is Libourne. Or perhaps St Foy la Grande. I suppose I have avoided your area because of the military zones along Aquitaine, but I have flown to Biarritz all in the Taylorcraft, and sometimes with the radio turned on).
