Cg-rla
  • Cg-rla
    1946 BC12D serial 9815 lycoming 0320 B2B 160 hp Gilberti STC , Airframes Alaska 2000 lb struts, Double tail brace wires, Hyd brakes, 21 inch tundra tires, 2500 fed ski"s, 1650 Full lotus floats, 5.5 hours range, skylight,extended baggage, icom 210, gtx 327, garmin 296, CHT, EGT, DG, 4 Point harness, Full restoration 2002. 470 hrs since.
    Re: Cg-rla
    Wow! Sounds like the full monty!
    Welcome to the forum!
    Have you got any photos?
      Re: Cg-rla
      Hi Murray its grate to see you on the site hope winter has been good take a look at the thread on the b model about the mods to t crafts talk soon Chuck Robert have been talking to Murray for a while and it is very impressive plane
        Re: Cg-rla
        HeyChuck I talked to you before Xmas and got wiped out when the site went down. Just got back and was trying to post on the airplane registry. Not too computer savy. ended up here. Hope all is well with you Later Murray
          Re: Cg-rla
          That is one serious tcraft!
          N27432
            Re: Cg-rla
            Nice! The red and white really works in the snow!
            Patrick Dixon
            1946 Taylorcraft BC-12D NC43328
