Maintenance Man's Glossary
  • Maintenance Man's Glossary
    For those doing your own maintenance, the following glossary is provided:
    HAMMER: Originally employed as a weapon of war, the hammer nowadays
    is used as a kind of radar device to locate expensive parts not far
    from the object we are trying to hit.
    MECHANIC'S KNIFE: Used to open and slice through the contents of
    cardboard cartons delivered to your front door; works particularly
    well on boxes containing seats and expensive leather clothing.
    ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets in
    their holes until you die of old age.
    PLIERS: Used to round off bolt heads.
    HACKSAW: One of a family of cutting tools built on the pessimism
    principle. It transforms human energy into a crooked, unpredictable
    motion, and the more you attempt to influence its course, the more
    dismal your future becomes.
    VICE- GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to
    the palm of your hand.
    OXYACETYLENE TORCH: Used almost entirely for lighting various
    flammable objects in your workshop on fire. Also handy for igniting the
    grease inside a brake drum you're trying to get the bearing grease
    out of.
    WHITWORTH SOCKETS: Once used for working on older British cars and
    motorcycles, they are now used mainly for impersonating that 9/16 or
    1/2 socket you've been searching for, the last 15 minutes.
    DRILL PRESS: A tall upright machine useful for suddenly snatching
    flat metal bar stock out of your hands so that it smacks you in the
    chest and flings your coffee across the room, splattering it against
    that freshly painted part you were drying.
    WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere
    under the workbench with the speed of light. Also removes fingerprint
    whorls and hard-earned guitar calluses in about the time it takes you
    to say, "Ouc...."
    HYDRAULIC FLOOR JACK: Used for lowering vehicles to the ground
    after you have installed your new front disk brake set-up, trapping
    the jack handle firmly under the front fender.
    EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering vehicles
    upward off a hydraulic jack.
    TWEEZERS: A tool for removing wood splinters.
    PHONE: Tool for calling your neighbour to see if he has another
    hydraulic floor jack.
    SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for
    spreading mayonnaise; used mainly for getting dog-doo off your boot.
    E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes
    and is ten times harder than any known drill bit.
    TIMING LIGHT: A stroboscopic instrument for illuminating grease build-up
    TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the
    tensile strength of ground straps and brake lines you may have
    forgotten to disconnect.
    CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool
    that inexplicably has an accurately machined screwdriver tip on the
    end without the handle.
    BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulphuric
    acid from a car battery to the inside of your tool box after
    determining that your battery is dead as a door nail, just as you
    thought.
    METAL SNIPS: See hacksaw.
    TROUBLE LIGHT: The mechanic's own tanning booth. Sometimes called a
    drop light, it is a good source of vitamin D, "the sunshine vitamin,"
    which is not otherwise found under vehicles at night. Health
    benefits aside, its main purpose is to consume 40-watt light bulbs at
    about the same rate that 105-mm howitzer shells might be used during,
    say, the first few hours of the Battle of the Bulge. More often dark
    than light, its name is somewhat misleading.
    PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style
    paper-and-tin oil cans and splash oil on your shirt; can also be
    used, as the name implies, to round off Phillips screw heads and can
    double as oil filter removal wrench by stabbing through stubborn oil
    filters.
    AIR COMPRESSOR: A machine that takes energy produced in a
    coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic
    impact wrench that grips rusty bolts last tightened
    60 years ago by someone in Springfield, and rounds them off.
    PRYBAR: A tool used to crumple the metal surrounding that clip or
    bracket you needed to remove in order to replace a 50 cent part.
    HOSE CUTTER: A tool used to cut hoses 1/2 inch too short.
    DREMEL - A rotary tool used to make a 5 minute job take 2 hours and to
    make material, which should remain in place, turn into artistic dust.
    Its high-pitched scream sends out a subliminal message of "Feed Me! Feed Me!" which is readily picked up by the receptors of the Male Brain. If not used with correct PPE, it can cause the break-up of relationships when the operator submits to its call for him to engrave his name on everything in the household.
    EXTENSION LEAD - Item used in conjunction with Dremel in order to
    increase the sphere of influence. In ideal circumstances, it can allow
    the operator to engrave his name throughout parts of his neighbours'
    households (I have no idea how they knew it was me).
    RING SPANNER - Designed specifically to fit over the Open-Ender Jaws of
    a Combination Spanner to use as a Cheater Bar to round-off Bolt Heads
    that are proving difficult to round-off with conventional Tools.
    Provides the option of snapping off the Bolt Head to enable the use of
    whatever you have left in that set of EZ-Outs.
