Testing double-posts and other vb software issues
  • Testing double-posts and other vb software issues
    This is a thread for me (& others) to see if we can duplicate posting issues.
    Re: Testing double-posts and other vb software issues
    Replying to same
      OK, here's the first problem (see attached).
      The software normally doesn't ask for this feature. Click on "Leave this page" will post once and once only
      Click on " Stay on this page" and your post will appear twice
        And immediately we have the second problem. For some reason the text is right-justified, which is not normal.
          Problem No 3 arises (see attached).
          There appears to be a software issue. Bob?
            ---o00o---(**)---o00o--- Kilroy was here
              hmmm.
              tcraft@taylorcraft.org
                Top of forum, click Advanced Search, get following at top of page:
                Warning: Declaration of vBForum_Item_SocialGroupMessage::getLoadQuery() should be compatible with that of vB_Model::getLoadQuery() in ..../packages/vbforum/item/socialgroupmessage.php on line 261
                Warning: Declaration of vBForum_Item_SocialGroupDiscussion::getLoadQuery() should be compatible with that of vB_Model::getLoadQuery() in ..../packages/vbforum/item/socialgroupdiscussion.php on line 337
                Search page still works. Using Ipad 2, iOS 6
                Mike Wood
                Montgomery, TX
                '46 BC12D
                N44085 #9885
