Kris, That's not a steal, but given that ski time is upon us...I would buy them. Make sure they fit your tapered axles. if that's what you have...or that you can devise a way to make them fit. Dick
Dick, yep. Stoddards/Reeve's had nothing, A.D. wanted $275 to make a set. I understand AERO makes them too, but when you factor in shipping & the wait... I'll get the used set. I believe it has tapered axles, how can I tell without taking a wheel off? Kris
Kris, the tapered axle should have a 3/4 inch nut holding the wheel assembly on, if it's a tapered axle...which is most likely the case. Here is a link from past discussions on ski bushings. It may clarify things. Click on the link and scroll down about 4 entries: http://vb.taylorcraft.org/showthread...light=bushings Dick
Thanks Dick, that was helpful. It's got tapered axles & the measurements from your diagram checked out on the used Atlee bushings/adapters. I was getting ready to buy the bolt ons Tim recommended, wasn't necessary & always happy to support local when possible. Got the first few inches of snow in Anchorage so it won't be long till the skiis go on. Kris
