Possible Source for Fairleads
  • Possible Source for Fairleads
    I found this on an older blog, (sorry-don't know who to thank on this). I know some folks have asked in the past about a source for fairleads. This is what I found on that blog, (no photos are currently available on the blog):
    Cable fairleads guide the control cables. There are 10 of them in the T-Craft fuselage. The original fairlead is a simple plastic tube with two retainer rings. It is simple and light but is made of phenolic and is no longer available.
    The Piper fairlead is readily available, is made of nylon, and is split so it can be installed with the cables already in place. The problem with a Piper fairlead is that it is longer than the T-Craft fairlead and slightly smaller in diameter. See the drawing in Photo 1 for a comparison.
    An acceptable substitute fairlead is available from Aircraft Spruce. It is called a "short fairlead segment" and is not shown in their catalog, so go to their website and search for the part number 40071-00. Each segment is half of a fairlead so you'll have to order 2 segments for each fairlead (20 segments make 10 fairleads). (Photo 2)
    The length of the short fairlead segment is exactly right for a Taylorcraft but the diameter is about 1/16" too small. If you wrap 2 or 3 turns of ordinary masking tape around the fairlead during installation the diameter will be just right. The masking tape also makes installation much easier as it holds the parts in position while you put on the retainer ring.
    A 3/4 inch snap ring can be used as a retainer or simply use the Aircraft Spruce retainer rings by slipping them right over the masking tape. (Photo 3)
    Cost? $.83 each for two segments and $.27 for a retainer, or $1.93 per fairlead. Total of just $19.30 to do the entire airplane!
    Update, I noticed this was from Robert Gustafson, one of our own. Hope I didn't repeat what he has already posted before.
    Re: Possible Source for Fairleads
    Good info. As I recall there are either one or two very small "fairleads" for the trim tab cables to go through. any suggestions of replacing those?
      Lee I don't think there are any fairleads on those. I think the cable go right through. I'll have to take a closer look next time I am out at the hangar.
        Thanks Marty
          Lee,
          I looked at my plane, and they sit fairly far back, but they don't look like there are any fairleads. I will try and find my parts info and see if they even list anything.
            These ones have two little copper fair leads driven into each end the steel tube that the cable goes thru.
            They are probably formed from a copper tubing say 3/16"
            Clean off the paint and I bet you see copper Marty.
            I think I have some will try to do a photo Thursday.
              Thanks, Dave. I looked backward into the fuselage with a very bright flashlight but cannot tell if there is anything in those small tubes. Obviously, I cannot reach them either. Being over 65 years old, with a restoration in there, who knows if there are any copper fairleads.
                Here are some pictures of the fairleads with copper inserts.
                They look like pieces of copper tube that have flared in standard flaring tool and then inserted in the steel tube.
                  Interesting, thanks for posting those Dave. I've got a video stick and may be the camera head will reach back there so I can see. That should answer Lee's question.
                    Please do a search on fairleads and then open the thread begun by James4438c dated 2-2-2011. In that thread you will find instructions for making exact duplicate fairleads at a very low cost using common tools and some phenolic tube from U.S. Plastics.
                    The trim fairleads should have thin-walled copper tube in them. Purchase from a hobby shop.
                    Best Regards,
                      Mark,
                      I've seen that thread, but just wanted to offer an alternative for folks.
