asssy case for A-65
  • asssy case for A-65
    I'm looking for an assy case for my engine.
    Found some but have a question for the group.
    Magnesium or Aluminum Which is better?
    Robbie
    TF#832
    N44338
    "46" BC12D
    Fond du lac WI
    Re: asssy case for A-65
    Yellow tagged no matter.
      Check both carefully for corrosion and wear in the oil pump cavities. The Magnesium ones are obviously a lot more prone to corrosion if neglected, but they are lighter. I have had some folks say they would be afraid of an engine compartment fire with Magnesium, but I figure if the fire is hot enough to light off a solid chunk of it (big chunks of Magnesium are NOT easy to light off with low temp flames, but a scraping or shaving is easy), I would already be long dead.
        I have a couple of ass. cases. You would need to have them inspected Bet to call me direct 419-573-5043
