McCauley prop question. 'CF' vs. 'CM' differences
    Re: McCauley prop question. 'CF' vs. 'CM' differences
    Ok, did some research, found a lot of data on this situation and the result is that I am more confused by what i found than I was before. So I am fading into the background on this one...
      I guess we'll probably never agree on this, but if the manufacturer states that the TSIO-520M is a direct replacement or interchangeable for the TSIO-520C then that's good enough for me. If an unknowledgeable FAA type refuses to give you a field approval and the old engine is no longer available, I really doubt that the only alternative its to scrap the airplane.
      Bob Picard
      N48923 L-2B Skis/Wheels
      Anchor Point, Alaska TF#254
        I mentioned this engine because we made that exact change on a Cessna TP206A. But is was via an STC from RAM Aircraft.
        I did research the propeller issue and confirmed two things: 1 is that McCauley does consider the 1A90 and the 1B90 to be interchangeable. 2 is that the FAA issued type certificate data sheet is "approved data" and that is where it states that the two props are interchangeable.
        I think if I were going to install a 1B90, I would fill out a 337 referencing the TCDS from McCauley. I am not completely convinced at this point that the 337 is even necessary but would do it "just in case". I am convinced that either prop can be used on the T-craft.
        Now regarding the tire ply rating....
          Read note number 10 on the TCDS.
          Best Regards,
