transporting stuff
  • transporting stuff
    I seem to recall reading a bush-pilot adventure book in which s/he talked about al variety of stuff s/he was called upon to haul.
    I think s/he mentioned tying stuff to the outside.
    Anyone with experience mounting something outboard in order to cart it around?
    external loads
    Mike, these links will give you some info re: external loads:
    and : http://www.alaska.faa.gov/ancfsdo/Ext-Load/Ext-Load.htm
    Dick
    Dick Smith N5207M TF#159
      Thanks - that's just what I was looking for; now, are there any moose in Northern Virginia? Is a cow an approved substitute? Mothers-in-law? - Mike
        Yep, I always wondered about lashing a fishing pole to a jury strut (facing the rear). I guess that is a negative...
        Eric H.
        Madison, MS
        N39240
          Eric,
          It works fine if you have a 2 piece rod.I always tied the 2 halves together in 3 or 4 places with a shoe string or zip ties before tieing it to the strut.I have also rolled them up in a sleeping bag a few times also....sleeping bag&fishing poles on one side and a tent on the other side.I always layed them on the struts against the outside of the jury struts and tied them off to the struts.I wouldn't want to put more than 20lbs or so on each side.
          I have done this a lot on Super Cubs&Huskys but only a couple of times on a t-craft.
            My 5 piece fly rod fits easily in the baggage thingy - Mike
              Hey Kevin,
              That is exactly what I had in mind. So is that something we can do without the restricted category and FAA OK?
              Eric H.
              Madison, MS
              N39240
