Re: Spiral Instability
Any time we make a 360 degree turn with one of our airplanes the outboard wing will have to travel farther
(about 200 feet). With a .5 mile circle and the inboard wing tip traveling 100mph the outboard tip will be traveling 2.6 mph faster. The difference in distance and speed will vary with bank angle. The greater the bank angle the less the difference. Unless the airmass changes to match the turn of the airplane the outboard wing will also have to have a higher airspeed. Just like the propeller has a greater speed at the tip compared to the hub. The slip or skid will change the speed also, but only while the slip or skid is changing.
