what is the best UNSHIELDED spark plugs to use in ercoupe cans on a C-85?
unshielded spark plugs
Re: unshielded spark plugs
Bob,
Don't know if they are the best, but I use M-41's with the cups.. The C-26's are also compatible, (I think if I remember correctly), but you would have to sell your first born to get a set. I have seen some C-26's of late on Ebay, new, though.Cheers,
They can be difficult to find. For a long time I was looking for them and couldn't find them. Now more and more are showing up but are not cheap. Here are links to what is on Ebay right now:
I was running C-26's on top. Worked great to eliminate the bumps. Had nearly 40 troublefree hours on them before the unscheduled landing. I scrounged a couple coffee cans full of used C-26's over the last couple of years. Most cleaned up real nice. Axs a bonus, I got about 100 copper washers in one can. I beadblasted and annealled them all. Work perfect.MIKE CUSHWAY
1938 BF50 NC20407
1940 BC NC27599
TF#733
I was asked in a PM about this so for anyone else interested. Here is some info regarding using the Ercoupe Cups I put on my plane this last summer. Doesn't eliminate ignition noise completely, but helps. I have a couple of other things to do but just getting the shielded plugs on the bottom helps a lot.
Link: http://vb.taylorcraft.org/showthread...t=ercoupe+cupsLast edited by M Towsley; 11-15-2011, 07:43.Cheers,
We use them all here ; you are correct the C-26's should have been taken out of service . Rumor has it that they still work just fine !Taylorcraft Foundation, Inc
[email protected]
