I have read that 85 pistons in the o200 require a slight chamfer on the piston to clear the head. has anybody tried to machine just past the cylinder into the combustion chamber to make room for the piston. the idea here is that typical hemi heads have horrible swirl. by cutting into the combustion chamber to make room for the piston there will be a ledge or shelf 90 degrees to cylinder wall and create more turbulence.
if not here would anybody know of a forum that explores motor subjects
