? for the stroker crowd
  • ? for the stroker crowd
    those of you with higher compression and the strokers can you still run car gas of 91 octane what is the highest compression to run 91 octane. can you in a dons dream machines motor
    Re: ? for the stroker crowd
    I dont run high compression because gas without alcohol is hard to come by in some areas, limiting your possibilities. Don's motors are certified for the gas that your original engine was certified for. Tim
      When you say "high compression" do you mean C-90/O200 compression or are you talking about an uncertified hot rod?
      The C-90 and O200 will run fine on 80 octane avgas or 87 octane auto gas, as will a C-85 with an O200 crank STC.
      New Yoke hub covers
      www.skyportservices.net
        well im looking at the c85 with o200 crank and rods
        you get stock o200 compression with this set up
        but id rather add the 85 pistons to it.
        my question i guess then can you still run 91 octane with the 85 pistons on the o200 crank and rods?
        or does anybody have an 0200 with 85 pistons running car gas?
