when you submit an application for an stc and it is accepted is that information available to the public. for instance if they make a belly pod for the another aircraft and the stc is approved can the general public see the engineering required and have access to the data so that generalizable points can be pulled and adapted to other aircraft without reinventing the wheel.
also has anybody seen a pod for a tcraft
