Does anyone know what throttle cable to buy for a BC12D with the Stromberg carburetor, Thanks
Throttle cable
Re: Throttle cable
I too used the Cessna cable from McFarlane. Its not cheap but it's far superior to the factory cable.DJ Vegh
www.azchoppercam.com
www.aerialsphere.com
Mesa, AZ
Re: Throttle cable
The one we used I believe is McFarlane #MCS1222-1S
Our Cessna 180 throttle cable measured 42" long and was a perfect fit. You'll also probably need a rod end for it and you'll have to ream the hole in the panel larger as the threaded housing on the Cessna cable is larger OD than the factory Tcraft cable.DJ Vegh
Mesa, AZ
