Fuel shut-off valve
  • astjp2
    replied
    Re: Fuel shut-off valve
    That is a special thread, Mil spec. You wont find anythink in any local hardware store....Tim
  • Hal
    replied
    Smooth move Hal.
    Thanks for the part number, likely I will need one. Seems you have solved a problem for me, even before I knew the problem existed. LOL
    Did the Hilborn tech say what the weird threads are? Just curious.
    Darryl
    I did not ask what the threads were. I took the fitting to my local Lowes aviation and could not identify them. It seemed like 1/2 inch was the right diameter but it did not match any thread pitch they had.
    Hal
  • flyguy
    replied
    Smooth move Hal.
    Darryl
  • Hal
    replied
    Hal, why reinvent the wheel?
    What do you mean? Am I missing something? I needed a valve to mate to my finger screen with an AN6 fitting on the other end.
    Hal
  • astjp2
    replied
  • Hal
    replied
    The Hilborn part number for the fitting is: 13-6BX4
    Hal
  • Hal
    replied
    Hi All,
    I bought one of these valves from speedway and it operates great. Virtually no friction. The only problem is that the threads on the coupler are some odd straight thread that I have never seen before. The coupler seals to the valve with an o-ring but the open end of the coupler uses the same thread. I needed 1/4 npt to fit into my finger screen. I called Hillborn and talked with a tech support fellow that found a short coupler with 1/4npt on one end and straight o-ring on the other. He said nobody had ordered one in years. I have the part number at home and will post it this evening.
    Hal
  • cvavon
    replied
    DC
    Also the fuel injection unit is also made for alcohol so the valve will not be hurt by modern auto gas chuck
  • flyguy
    replied
    Turns out that my old valve is just fine now that I have checked it out, but while I have the system apart I am going to go ahead and get one of these and see if I can hook it up. End to end size is very close.
    Worth the money just to try out a modern valve; if I can get it to fit in neat and solid.
    DC
  • Dick Huish
    replied
    It's called "deep discounts" due to large volume purchases. When I was in business I was a dealer for Cooper Avaition but I bought my hardware fron Dillsburg Avaition for less than I could get it from Cooper Even tho all the material came from Cooper.:clue?:: Dick
  • flyguy
    started a topic Fuel shut-off valve
    Fuel shut-off valve
    Talking with the guys at Speedway Motors I have been able to find the manufacturer of the sexy shut-off valve that I have mentioned on the forum before. Hilborn fuel systems.
    Back with the Speedway link in a sec.
    Notice it is more expensive from the Mfgr. Hummmm.
    DC
