Re: Another proppeller accident!
Frank,
If you need to attach to a post or something that the 'snap-shackle' wont go around, you put the cable around the post, and attach the shackle to the cable itself. You need to be sure to attach it to the tiedown cable, and NOT the release cable.
As for attaching it to the right side of the plane and passing it under the plane, I don't see why it won't work. The release cable will still release the shackles when pulled, and the retract mechanism will pull everything under the plane and into the cockpit. I have a handhold on the right side of my plane, also, so I'll try it tomorrow to be sure.
Louie
Frank,
Louie
