Brake Bellcrank
  • Brake Bellcrank
    During the cold months here in NY state, I am trying to make soom of the parts that are missing from my project.
    I am making the bellcrank between the landing gear V that works the brakes. The shaft appears to be 2 1/4 inches long. But, from some of the pictures I have seen, the bellcrank is not located in the center of the shaft.
    Does anyone have some dimensions for this?
    Ray
    Re: Brake Bellcrank
    why not just replace it with a used one?
    taylorcraft@neo.rr.com
      Re: Brake Bellcrank
      I have the parts made, just need the measurements so I can weld it up. Can you help?
      Ray
        Re: Brake Bellcrank
        Ray
        You are correct...the bellcrank isn't centered on the shaft. I just measured one of my spares, the shaft is 2.260", and extends out the front of the bellcrank .780", and out the rear 1.390".
        Garry
          Re: Brake Bellcrank
          Anyone have a pair of extras?
          Mikeg
            Re: Brake Bellcrank
            Thanks for the info.
            Ray
