Attachment Tabs
  • Attachment Tabs
    I have two welded on tabs that have me puzzled. They are located just below the aft wing attach fitting and just above the upper door frame tube. One on each side welded to the aft side of the verticle tube. Confused? Anyone know what is attached there? Aircraft is a '40 B model.
    Mikeg
    Re: Attachment Tabs
    Mike, If it is on the top of the upper longeron, it might be where the tapered piece goes that blends the cockpit area into the fuselage.
      Re: Attachment Tabs
      Its not a headliner bow attach tab?
      PV
        Re: Attachment Tabs
        Tabs are located on the aft side of the vertical tube that comes out the bottom of the rear wing attach fitting cluster. Lacated about half way between the rear wing attach fitting and the 1/2" square upper door frame tube.
        Is this where we locate a block of wood to attach the aft headliner bow?
        Mikeg
          Re: Attachment Tabs
          Mike, I didn't have a chance to look at my fuselage, but I think it might be an attachment for the baggage compartment support. Tom
            Re: Attachment Tabs
            May be like the last guy said ; how about a photo?
            taylorcraft@neo.rr.com
              Re: Attachment Tabs
              Why didn't I think of the Forrest. Now if I can figure out how to do that.
                Re: Attachment Tabs
                Are you are describing the lower tab in this photo?
                  Re: Attachment Tabs
                  Yes, but mine is a little lower. About 1" above the 1/2" square upper door frame tube. Mine is a '40 B model with now back windows.
                    Re: Attachment Tabs
                    I took pretty much the same picture that Richard took. This is how I used the tab. I think the tab is used to hold the wood former in place.
                    Norm G
                      Re: Attachment Tabs
                      Thanks. Gone Senior, I guess. I remember that wood from my '41 now. Anyone know how the aft headliner bow attaches in a '40 B Model, no rear windows or hat shelf behind the baggage compartment?
