Re: What Prop?
Here's the FAA answer. NO. You must go by the engine rating (i.e. the approved operating limitations).
In the case of the STC being sold by Aircraft Specialties to install the O-200 crankshaft in a C85 does not alter the FAA approved engine ratings. (i.e. it is not approved to operate at different power/RPM than the original C85. I am guessing they demonstrated "equal or better" performance.) Therefore, all of your operating limitations remain the same if you install this engine.... including max RPM. So this means you cannot legally use a different propeller than is already certified for the C85 is approved with on your airplane, unless you are prepared to do the necessary engineering work to demonstrate to the FAA how the prop and engine combination comply with the airworthiness requirements.
Sure... technically the hybrid C85 "stroker" engine will produce more horsepower at certain RPM levels than a stock C85... this is not difficult to reason or to demonstrate. But there is a whole lot more to gaining FAA approval to operate that way.
So this means any propeller that allows the engine to operate (turn up) to a higher RPM/power level must be scrutinized against all of the applicable requirements. This would likely involve testing and/or analysis work. Or if you want to propose a propeller that is different than already certified with a C85, but does not cause a difference in the RPM/power levels... it can be done. Same requirements, but a lot less compliance work- since there would be no change to to the limits.
Originally posted by T-Rex
View Post
