MA 2 carburetor float needle
  • MA 2 carburetor float needle
    Does anyone know if the float needle seat is different for the rubber tipped needles and the all stainless needle. I want to change out the rubber tipped needle on a spare carburetor. Cheers, Galt.
    Re: MA 2 carburetor float needle
    Not sure what carb you're talking about, but if it's a Stromberg, the answer is yes. The steel needle uses one seat and the neoprene and Delrin needles use another.
    New Yoke hub covers
    www.skyportservices.net
      Hi John, It's a Marvel Schebler MA-2. I should have made that clear. Cheers, Galt
        Didn't know there was more than on needle option...
        New Yoke hub covers
          You did not give engine model or carb "10" number so it's a guess.
          For Lycoming O-145 B-1,B-2,B-3,C-1,C-2,C-3
          the application is a A10-2065
          MA-2
          Float Setting 7/32
          Valve & Seat Assy -Float A233-551
          There is also a MA-2, A10-2065-P used on MANY Lycoming O & GO 145
          versions.
          It appears that is used with a Fuel Pump & uses a different needle & seat.
