Torque values
  • Torque values
    Can anyone help me out with the torque values of the prop bolts, and the crankcase through bolts for a C-85-F engine, with a metal prop and a flanged crankshaft ? I will be forever grateful for the info.
    Don
    Re: Torque values
    From Page 80 of the overhaul manual:
    Bolt, Propeller hub, 3/8-24, 16.7-18.3 Ft-Lbs
    Best Regards,
      Re: Torque values
      Mark, Thanks for the info, and the quick reply
      Don
        Re: Torque values
        Get yourself an overhalu manual if you're messing with the through studs.
        The torque values given above are for a wooden prop. Metal props are 360 inch lbs (or 300, depending on who you ask...)
        New Yoke hub covers
        www.skyportservices.net
          Re: Torque values
          Also pay attention to the torque sequence to save yourself some heartaches later down the road.
            Re: Torque values
            Thanks for your input, John and Terry. Where can I purchase an overhaul manual?
            Don
              Re: Torque values
              Both Sens, and MCaulley have the torque values on their websites, based on what prop you have. Tim
                Re: Torque values
                Dry torque of 25-30 Ft. LBS. will install your propeller correctly. As long as it is a flange mount, not a tapered flange installation.
                Hope this helps, thanks.
                Gary L. Peak
                McCauley Field Service Engineer
                Product Support Dept. 767
                7751 East Pawnee
                Wichita, Kansas 67207
                Phone: 800-621-7767
                Phone: 316-831-4021
                Dennis McGuire
