Whoever took my project plane apart 20 years ago thoughtfully cut away the wing tank plumbing, wadded it up into a ball and threw it into a box. Thanks.
I have: about 4 ft. of 3/8" kinked copper tubing, both ends cut off, and a frozen solid junk Imperial valve with no handle. So I'm nearly starting from scratch here. Any input would be welcome.
The tube: is copper the best? maybe aluminum tube? or a long hose? 3/8"? 1/4"?
Routing the tube: it looks like it should be routed down in front of the door frame next to the aileron cable that runs through that area. Or maybe inboard beside the door frame?
Mounting the valve: I'll use an Apollo ball valve... mounted by the wing? (doesn't look like much room between the wing and the fuselage) Is there a clever way to mount a valve up there? Maybe it's better to mount the valve under the panel?
