Did you know?
  • Did you know?
    Did you know that if you squirm around enough in the spacious Tcraft cabin, while working under the instrument panel, that you might unknowingly manage to push the cable from the right side of the rudder bar onto the arm to which is attached the cable to the elevator? And that when you check the controls prior to takeoff, that rudder deflection also moves the elevator and vice versa? And that you'll probably have to shut it down and look around a while before you figure it out?
    Mike V.
    Re: Did you know?
    Hi Mike ,
    No I did not know that.
    Thanks for the tip. I imagine that its not obvious that it happened either.
      Re: Did you know?
      That would make for some interesting flying...and a real bad day. Tim
