FAA CAR docs.
Tags: None
Re: FAA CAR docs.
Our airplanes were certified under car4a as I recall, TCDS will give you that info so verify it there.
You might use that old CAR info to justify or rationlize or understand how the thing was originally designed/built/repaired and use it to your advantage in repairs or alterations.
One example the old CAM 18 lists landing gear repairs that were accidently left out of ac43.13 and using the old data you can justify them.
Re: FAA CAR docs.
Remember Group II approvals are good too! Car 3 & 4a are the Taylorcraft early approvals...Taylorcraft Foundation, Inc
[email protected]
