Vertical stab bracket???
    Re: Vertical stab bracket???
    So does that mean not a deluxe then?
    Thanks for all the info....
    Aaron
      Do you have the original equipment list, that and the weight are the factors.
      back windows, cast grills, all that good stuff when she came out for flight test would make her a bit heavy. Can't really tell , she is mid range.
      taylorcraft@neo.rr.com
        With the records showing it came out as a BC12, the weight, and the parts you have I would say it was a deluxe from the factory. Tom
          Originally posted by mikeg View Post
          Aaron,
          Careful, if you get the fabric too tight in that area the straps will not fit. Haven't gotten to the airport yet to measure screw to screw. Tomorrow.
          Merry Christmas
          OK, my '41 DeLuxe (s/n 2654) fin strap length measures 29" from the center of one screw head to the center of the other screw head as measured around the fin fabric. The center of the forward screw head is 3/8" aft of the fin leading edge. The center of the aft screw head is 1 3/4" forward of the fin trailing edge. Hope the helps.
          NC29804
