Hey Guys,
Finally got the wings on my taylorcraft and got her in the air. I have a C-90 with a 71/42 pitch prop. I'm getting off the ground in about 400 ft. (1400 lbs gross) 2500 rpm on takeoff. 55 mph seems to be the earliest I can pull it off the ground with 8.50/6 tires. I have already adjusted the wings in and out on a couple of occasions, and are at factory specs. Stall seems to be in the range of 48-50 mph @ 2000 ft above sea level and 80 degree F. Cruise indicates 88-90 @ 2150.Are these numbers looking close to what they should be? Are these numbers realistic? Obviously when it gets down to 60 degrees its going to help, but it doesn't seem to be in the same ballpark as my PA-11 that I've flown for many years.(85 hp) I'm an A&P and have a few thousand hours in taildraggers (PA-11, Champ 7EC C-90, PA-16, and a hopped up PA-20) but only about 15 hours in this T-craft total. Any advice would help. The plane does seem to climb very well. It is a true joy to fly though and adding all the new glass to the airplane opened it up alot! On landing we are touching down around 55-57 indicated, 65 over the threshold. Thanks for all the help and I do appreciate it. Here are a few pics and one with a North Dakota sunset over the big lake.
Milo
Milo
