Re: Rough Running at Full Power
You have a NAS3A-1 carb.
1. Is the mixture installed? If so is it hooked up? If not is it wired rich or have a cover plate? If cover plate installed, is the reed valve plate installed still? If plate installed, is it tight and not leaking?
2. How old is the fuel hoses? Might be collapsing internally. How are they routed? Are they routed away from the exhaust?
3. Intake leak would not cause rough running at power, it causes rough idle and or hard starts.
4. What measurement didi you set the float level at?
