Speaking of GPS...
  • Speaking of GPS...
    What are you using if any? I'm having a great time with my Magellen 315 which I"ve had for 5 years, but costs may have dropped and features may have increased since then - Mike
    Re: Speaking of GPS...
    No one wants to talk about their GPS units Mike?
    Mine is a Magellan Meridian, no model number that I can find.
    It really isn't designed in any particular way for aviation, but it has WAAS and several functions that make it very practical in that usage.
    It has an airport data base, several years old, but they haven't moved many of the airports that I use to different locations lately, so it works pretty good so far.
    I must say that I really like it.
      I located a db of NavAids that someone had reformated and I fed it to my 315. Worked fine, but no longer exits and it's been so long, I fear I won't remember how to use it when I need it. I ought to dig out the 315 and try it out again. I was careful to remove the batteries. - Mike
        I still use my old 315. I have a new Magellan but it's just too big to use in the small Tcraft. I like the 315 because with one button I can find all the nearest airports.
        Eric Richardson
        1938 Taylor-Young
        Model BL NC20426
        "Life's great in my '38"
        & Taylorcoupe N2806W
        TF#634 :tup:
          I guess I got carried away with the pretty display; but you are correct, the 315 does what I need. Does yours eat batteries? - Mike
            No,but check & make sure the back light isn't on. You can't tell in daylight,but it will cause it to eat batteries.:tdown:
            Eric Richardson
            1938 Taylor-Young
            Model BL NC20426
            TF#634 :tup:
              I have Lorance 600c I have not been able to fly engough with it but I bought it for it size came with nice mounts what fits in the right control colum with a clamp.
              works well and is easy to use.But ! if you deside to make water white what function take a lot of memmory so it can frezze on you and it is not in the manual how to un frezze it: so here goes it:To hard bootPress and hold both power and pages for 3 to 5 seconds. Now you can reprogram your settings and take away what you over loaded it with.
              I think the larger model works the same.
              Len
                ops:That's what I have a Lowrance 1000 to go with my 315. It's just too big for the Tcraft so I still use the 315.
                Eric Richardson
                1938 Taylor-Young
                Model BL NC20426
                TF#634 :tup:
                  Hanging on the wheel of my BC12D is a first generation Trimble Flightmate. It's database is hard wired to a PROM. Its display is text made of dots, but it shows me groundspeed and heading and time to station (for my hand-entered local waypoints).
                  I was an early adopter of GPS with the Trimble and it served many years including going through my instrument rating in the Cherokee-235. It is simple and basic (like the TCraft) but it serves its purpose and I am used to its ways (like the TCraft). One of these days I may upgrade, but there seems no hurry. It works just fine.
                  Skip Egdorf
                  TF #895
                  BC12D N34237 sn7700
                    I have Garmin 495 which I used for my trip to Alask last year. I was fantastic/ It even has terrain clearance which was great in the mountains. It has colors and compared to my old Skyblazer (no comparaison). Worth the money
                      I use the Lowrance 2000c mounted on a lap board. The big display is real nice, and has a number of options on display format. It uses the Jeppsen data base for airspace and airports. I have the power connected to a 5 amp hr gel cell in my transponder box strapped in front of the seat. I used a hood and had a friend up as a safety pilot to see if I could use only it if I had an emergency and had to get down through the clouds. Spent about 45 minutes climbing, descending, and turning. Then navigated to an airport simulating descent to circling altitude. I managed it with some sloppy heading control -- but that could get better with practice. Hopefully, I'll never have to use that skill, but it is comforting to know I could get it down in and emergency.
                      Dan Brown
                      1940 BC-65 N26625
                      TF #779
                      Annapolis, MD
                        Originally posted by DanBrown View Post
                        ... a 5 amp hr gel cell in my transponder box strapped in front of the seat.
                        Dan - could you describe your setup? - Mike
                          Monday looks like a great flying day here -- I'll take some photos of the setup and post them here.
                          Dan Brown
                          1940 BC-65 N26625
                          TF #779
                          Annapolis, MD
                            Here is a photo of the GPS on my lap board with power plugged into the transponder box, portable transciver and intercom strapped in front of the seat.
                            Dan Brown
                            1940 BC-65 N26625
                            TF #779
                            Annapolis, MD
                              Hi Folks I am about to buy a new gps, what do yall think the most bang for your buck is this day and time.
