Gas on Windshield
  • Gas on Windshield
    Sometimes when taking off or landing, I have gas shoot straight up like a geyser out of the cap through the dipstick hole. Another taylorcraft and cub on the field doesn't seem to have nearly as much problem with it as I do. I"ve looked at their caps and only difference is slightly longer channels or nipples that the dipstick goes through. I keep my tank full as much as possible to prevent condensation. Anyone else have similar problems, and any quick remedies (other than not keeping the tank full). Also, what can I do to protect the windshield? I generally clean it with non-ammonia window cleaner and/or use pledge on it.
    Thanks
    Randy
    Re: Gas on Windshield
    I would suspect the tank is "oilcaning" seams unlikly but?
    Is the tank secure in it's mountings?
    Anyone else have another idea?
    Len
    Foundation Member # 712
      The only time I've had that happen was en-route when I started to drain a wing tank too soon.
        Our BC-12D does the same thing. I usually don't fill the tank full unless I am going on a longer flight and will need the additional range. It usually happens upon landing on a turf strip when the tank is full. I don't think there is any issue with the tank itself, just splashing out.
        (I have seen a stream of coffee come up out of my travel mug about 12 inches while driving down our not very smooth gravel road. This is a mug that has a lid on it with just a small slot for the coffee to be sipped out of. So I equate that with what happens with the T's fuel cap)
        Mostly we just clean the windshield with water and a hand. When I use "something" it is lemon pledge.
          I have never had that happen unless I dumped a wing tank too soon
            Fearofpavement
            You describe exactly what happens to me. Guess I'll just keep the windshield clean and protected with the lemon pledge--it smells a lot better than the other window products.
            Randy
              Randy,
              I have had gas splash from the hole in the cap a few times while taking off from really bumpy fields with a full tank. If you can borrow a cap with a longer guide for the wire and it helps then it wouldn't be all that much trouble to replace the guide in your cap and repaint it. I agree that it's a good idea to keep the tank full and wouldn't want to change that.
              Best of luck,
              Buell
              Buell Powell TF#476
              1941 BC12-65 NC29748
              1946 Fairchild 24 NC81330
                Remember if you change the length of the float guide it will change your previous reference of how much gas is left in the tank.
                Carl
                TF# 371
