I saved the Taylor-wire when I removed the fabric. but the are still embedded in a 1" strip of 3 layers of fabric. It takes about 5 min. per wire to remove the fabric from the wire. Is this a false economy? - Mike
false economy?
Re: false economy?
The wire just doesn't fit right and taylorcraft wire is not available as a far as I know.
So in my opinion economics aren't the issue.
But I suppose that you could compare your time spent recovering this wire to the time that you will spend bending "z" s into new wire that is too long (and buying the wire).
Maybe soaking them in lacquer thinner will make it easier?
Re: false economy?
That's the ticket Mike, a tray of solvent with alum. foil over it and the wires soaking in it overnight. Should peel apart with no problem then. Good call Dave.Originally posted by drude View Post
Maybe soaking them in lacquer thinner will make it easier?Taylorcraft : Making Better Aviators for 75 Years... and Counting
