Re: Project is home
You can use the glue over anything. You can make repairs right over paint any paint, just sand and apply. STC'd over any other fabric complete system. That means if you have dope finish and you get a rip you can just apply the patch right over it without stiching.
Here is what I have found out about the primer. The white metal primer is very thick, I thin it down. Wash everything up with water and you do not waste any money on thiners. The stuff is very tuff. The 170B you see in the photo was painted with SS. The owner did not want me to paint the door sill white because he said it would just get scuffed up and dirty. I told him it would not be a problem. After painting, climbing in and out for 2 weeks installing the clomplete new interior and panel you can see no evidence that anyone even climbed in once.
The primer is just as tuff. I dropped a filter on the floor and in the morning it would not come off. It ripped before departing the dirty floor!
You should not use powder coat on a fuselage. You cannot see cracks in the steel. Keep in mind also that the strength does not come from the fabric to metal it comes from the overlap of the fabric. The fabric to metal is just to keep it there to get it tightened. This is why you have a 1", 2", and 3" overlap requirement from the FAA on tapes and such.
The only thing that is a drawback of the SS paint is that it needs to have the waterborn primer. It does not like to go over other primers. The thing is the SS primer is better than anything else out there anyway so it is not much of a problem.
Dan
Dan
