Re: Steel Needle Stromberg Carburetor
I should add that when you are on final in cold weather the reason why the carb heat doesn't help too much is the engine isn't preducing much heat so you don't get much heat to the carb. I sure if you thought about it a bit you would know what I am talking about.
