Rudder cable exit holes
  • Rudder cable exit holes
    The rudder cable exit holes on my old cover (BC12-D) look as if they were an afterthought, stabbed into the fabric with a rusty pocket knife. Functional, I suppose, but really ugly.
    Question: is there a nice tidy way to make these holes? Anyone use leather patches?
    Bob Gustafson
    NC43913
    TF#565
    Re: Rudder cable exit holes
    Mine has black leather patches that look really nice. Same shape as the cross section of the wing struts (thick airfoil), with a very careful slice from the cable hole to the trailing edge so you can install it. I liked them so much I made one for the where the jury strut and pitot/static lines exit the bottom of the wing. Looks really classy and affords some measure of resistance to tearing. Highly recommended!
    If you use Stits covering, you can burn the hole with a soldering iron (same way as they want you to do the drain holes) instead of cutting. This will also resist unraveling or tearing.
      I burned the hole with a solder iron, then glued an aerodynamic cover so it hides the hole. Tim
        Bob,
        Here's the drawing for the leather patches over the rudder cable holes (and the hole for the trim tab pushrod.) It calls for "flannel-back leatherette" vinyl but I went to the craft store and got small pieces of real leather.
        Joel Severinghaus
        Des Moines, Iowa
        TF# 657
          I like to use medium canvas in a teardrop shape like in the pattern Joel showed, glued to the fuselage fabric. Then I cut a patch of fabric that is about an inch larger all the way around and cover it with that... looks pretty good and they really wear great.
