Mark fuel gauge
  • Mark fuel gauge
    I have generated usable fuel remaining vs. fuel gauge wire height for 3 point stance and flight attitude. While on the ground I can measure the wire height with a ruler. Is there an FAA approved way to mark the fuel gauge wire so I can read usable fuel while in flight. Obviously having something like paint come off and contaminate the fuel would be very bad. I can't think of a way off the top of my head.
    Danny
    Re: Mark fuel gauge
    We have a couple notches filed in our fuel gauge wire. One reads half tank and the other I use as "be on the ground before it gets there" but not sure of what its significance is in gallons. It's about an inch or so above bottom.
      Re: Mark fuel gauge
      For what its worth, when I reworked my fuel tank float I used a stainless welding rod to the float. I drained the tank, put in 3 gallons of fuel, and then formed the bend on the rod to just touch cap. Logic being I can estimate fuel from amount of rod drop, but when the rod bend touches I would know I had 40 minutes left, not that I have ever let that happen..
        Re: Mark fuel gauge
        I have used colored (painted) sections of the fuel wire that indicate 1/4, 1/2, 3/4 and empty since 1982. Never had a problem. Dave
          Re: Mark fuel gauge
          What kind of paint did you use?
          Danny
            Re: Mark fuel gauge
            I generally use rustoleum
              Re: Mark fuel gauge
              I never wasted my time, I use the Univair cub cap and when it bottoms out I have 30 minutes of fuel left. Tim
