Re: tail wheel tie down for hand propping
Had 2 cents in my pocket so I thought I would weigh in on this subject (I finally know something about something from experience ;-)
Most of the time, I fly by myself and I never thought about the need for an Armstrong starter until after I bought N44057. So here is my technique for the detail-oriented, anal person that I am.
Tie tail with rope; set parking brake; block front wheels with two wood chocks roped together with a rope loop up to the foot step on side of cabin. Mag off, pull thru 5 blades.
Stand on right side of airplane, straddling the wheel. Reach in to crack throttle, call clear and turn mags hot with left hand; with two fingers on end of blade, pull blade sharply (only time it didn't start on first blade as when I forgot to turn on mags!). When engine starts, glance at oil pressure gauge and adjust throttle.
Back away from side of airplane. When engine warmed and throttle adjusted to keep pressure off tires in slow idle, untie tail. Carefully climb in making sure not to bump the T-handle on the brakes. Buckle up, hold brakes, reach down and pull chocks out and toss to side, and away you go.
I like the idea of the mag switches on the side of the airplane boot. Is this OK without a paperwork change?
Finally, I made the Bingelis release device talked about previously, but it didn't work very well. On more than a couple occasions, I would pull the pin but the rope would hang up on the end of the jaw. Could never figure out why but seemed that the angle of the jaw was a little too shallow. Even after radiusing and polishing the device several times I could never get it to work reliably. I just went back to tieing down the tail.
Jack Dernorsek
'46 BC12D
Rostraver Airport, Belle Vernon, PA ( FWQ )
Jack Dernorsek
'46 BC12D
Glad to hear you are no longer in a hospital traction bed!
