Re: strut attachment AD - failed
Visualize your strut as a 10 foot long pry bar.
What you don't want to do is move (or allow to move inadvertently) the unattached (upper) end of the strut fore and aft as you will be using your 10 foot "pry bar" to "spread" or bend the strut attach fitting. Being aware of the issue will likely prevent it from happening but your "helper" also needs to be cautioned as to the importance of fore and aft movement. The fitting is steel and fairly robust but won't stand up to that type of force. I don't think you would damage the fitting by tapping the strut end in or out of the fitting with a mallet. Just keep in mind: force in and out ok, force back and forth NOT OK.
