Martin wire:ribs - 1:1?
  • Martin wire:ribs - 1:1?
    I'm carefully removing the martin wire from my wings. can it be re-used? do I need to keep each piece of wire associated with a particular rib (so the prongs and holes align? - Mike
    Re: Martin wire:ribs - 1:1?
    I HOPE you have Taylorcraft wire! Yes save all.
      Aircraft Spruce and the factory both have clip wires for sale. Does anyone know if the spacing of the clips is correct?
      David Johnson
      Wichita, Kansas
      TF#958
      BC12-D
        Will I need to be able to match each piece with the rib from which it came? - Mike
          No Mike, matching wire to ribs should not be required.
            If you order new you need to make sure you tell them it is taylorcraft wire,not just martin wire . There is a difference.
              So Kevin, where can Taylorcraft wire be purchased?
              Brad
