Screw attachment of wing fabric
  • Screw attachment of wing fabric
    Looking for some info on attaching wing fabric to stamped ribs with self-tapping screws. Any ideas?
    Aeroncas used #4 x1/4" sheet metal screws which worked fine till the hole got enlarged. Sometimes more holes had to be drilled to get the screw to tighten up. Also, Citabrias used 1/8" aluminum pop-rivets which works great, easy to install and fast. This would work fine on the stamped rib provided the flange is large enough. at least 3/8". You might need to get a field approval since they didn't come from the factory that way.
    Frank Isbell
    N23698 BC-65
    N260PJ PJ-260
      screw STC
      DAMIT Robert
      I thought we cleared this up years ago
      STC SA1-217 belongs to R.J.R. Airdrome INC.
      114 Kruser Blvd
      Chandelle Airport
      Dover DE. 19901
      telll # 302 736 3447
      Roger Kruser
      He sent me the stc paperwork for $25 in 2001
      the approval was done in 1959
      B 52 Norm
      1946 BC12-D1 Nc 44496
      Quicksilver AMPIB, N4NH
      AOPA 11996 EAA 32643
      NRA4734945
        Sir, do you have a copy of that STC that you could send me? I’m not having much luck contacting the STC owner. Russ Williams. 214-205-7555
