I am in need of a left landing gear leg for a 1946 BC 12D. Any information you have will be greatly appreciated.
Landing Gear for BC 12D
Re: Landing Gear for BC 12D
I am in the process of building a new set for my Clipwing (experimental) Any AP that is good at welding should be able to repair your existing gear. I think the materials for my entire new set- including new straight axles and new strut material was about $500. I will have 30-40 hours in them when I am done building this new set. If it were just a repair that should be much less. We have cut out the old tapered axles and replaced lots of tubing before. It takes time but is better than taking a chance on getting crummy gear. If the axles and fittings can be salvaged the rest is easy.Eric Minnis
www.bullyaero.com
Clipwing Tcraft x3
I also needed a left gear leg it took me awhile but what i ended up doing is finding the best one and having it repaired.Lance Wasilla AK
