float equiped T ....prop question
  • float equiped T ....prop question
    I have a C90 and I'm swinging a Sen 74 39 prop at 2400 static.
    I have been told by another Tcrafter that the Sen is junk and to
    throw it away and get a McCauley 74 40. Is there that much of
    a difference? What are the rest of you using and what is your
    static, full open cruise RPM and your cruise speed?
    Robert
    Robert Bradbury
    BC12D Experimental
    C-FAJH C90
    Sen. 74X39 prop
    Seaplane 1650 Floats
    Re: float equiped T ....prop question
    I know of one that is a 74ck43, on an O-200, static is 2300 or so and it tops out at 2750 @ 106kts. Tim
      Was this a McCauley clip tip prop and this was on floats? Wow! That would
      be a lot of pitch even for a 0-200 especially on floats.
      Robert Bradbury
      BC12D Experimental
      C-FAJH C90
      Sen. 74X39 prop
        No, Sensenich M74ck-0-43, not an approved combo but the prop is rated to 100HP@2650. Its on a T-craft with 8.50's and that was wide open throttle in level flight at 2500MSL in a square pattern verified by GPS. Tim
          The general consensus seems to be that the Sensenich 76-AK-2-40 (or 38 pitch) is the best seaplane prop.
          I'm not sure how much of a difference it makes compared to a similar McCauley. Can't see it being much better.
          The only way to tell is to try it on YOUR engine.
          I run a 7140 McCauley on an O200 (actually a C90 because it has the 530788 cam). Static (tied down) is about 2500-2550. It'll run up to 2900 in cruise if I let it.
          I'm thinking about going to a 7440 or repitching mine to 7142.
          Works good for getting off on floats or skis but, once I'm in the air I always wish I could use some more of the top end power.
            I have Edo 1320's the Model19 conversion and a c-85. What do you guys think the best sea prop would be? Right now I have a McCauley 1B90 70x46. I am contemplating overhauling and repitching or buying a longer prop.
              76-40 if you can find one. tim
                Do you think I will get my static rpm into limits with that mutch length and only 85hp? How do you think the approved props would work, the Mac 1B90 71x42 or the Sen 74CK-2-42. Do you guys know what the difference is between the Sen AK and CK props.
                  Well the Borer props are 80+ inches, if you need go flatter. Tim
                    If you keep the current prop...
                    You have too much pitch... I'd flatten it to about 42 or 40. It will make a noticeable difference. But you're going to notice a difference in cruise speed.
                    If your concerned about losing cruise speed try 42. If you want to optimize off the water performance on hot days with a full load go to 40. If you're not sure try 41 :-)
                    What's your static RPM with the 7046?
                    I used to run a 7140 on a C85. The flattest 71 inch 1B90 I've heard guys using is a 38 pitch.
