After adding about 3 gallons of fuel to the right wing tank, went inside the cockpit for a rag and smelled fuel. Looked up on top of the right door where the right fuel valve is...nothing, then I notice a puttle and drops comming from the fuel center tank. UUPS, the valve is open. Nope. It was closed. Tried different positions and the fuel continued to leak. Well, I place a bucket to catch the fuel leak and opened the headliner to take a look at the fuel valve. It operates very nicely...but I'm guessing that the inner workings are not. I placed the valve on the OFF position for about half an hour and the fuel continued to leak
. Check the fuel level in the right tank after 2 hours and... yes it was down about the same amount of fuel in the bucket. Well, let me put the handle in the middle position, nor on nor off....same result.
Any ideas...... I am tempted to remove the fuel valve and then....what? Can the valve be serviced? If not, would need a new valve....where to get it.
Any help and ideas are very welcome.
still slowly draining the right tank in a bucket...from the bucket to the lawn more
Thanks
Ralph
. Check the fuel level in the right tank after 2 hours and... yes it was down about the same amount of fuel in the bucket. Well, let me put the handle in the middle position, nor on nor off....same result.Any ideas...... I am tempted to remove the fuel valve and then....what? Can the valve be serviced? If not, would need a new valve....where to get it.
Thanks
Ralph
