mag timing circuit
  • #31
    Re: mag timing circuit
    Sure can. Just finished layout of schematic tonight. Still have to make it with dark lines so it will copy well. I will also take photos of back/front side of board and post them.
    • #32
      This is the diagram for the circuit board.
      The mag connection is made across the switch at the top, which is the small metal piece attached to the back that closes the power circuit. You will likely want the remove that. It would be a good idea to put a switch in the wire to the mag so you can turn the thing off and on without disconnecting it and it will minimize voltage spikes on the board caused by the mag coil when you hook it up.
      • #33
        THANK YOU VERY MUCH!!!!!!!!!!!:tup:
        • #34
          OK, finally getting around to messing with your timer. Any recommendations on long to make the wire leads? I think, for grins I will mount the unit in a box with a switch too. Again Thanks Darryl, Larry
          • #35
            Just long enough to get to the mag. :rolleyes2: Sorry, that is an old joke. I have a box from Radio Shack that is a perfect fit, don't know if they still stock those or not. The lead length should not make any difference as you are dealing with pretty low frequencies.
